97 civic dx brake upgrade
okay I've read almost every forum out there on putting integra brakes on my 97 civic dx. and I still dont have a solid answer. I'm using a 99 Acura integra steering knuckles with all the OEM parts to go on my civic. the only difference will be a bigger brake piston correct? from what I've read the rotors are the same size as the civics along with pads. but my main question can I use 99 integra knuckles on my 97 civic to get a slightly better braking power? the integra knuckles are longer so how do you deal with the camber? I'll be lowered on coilovers soon, it's a project car and the whole front suspension is ripped out to get a refresh and powder coat so I figured get some better brakes from the junk yard while I'm here. will the integra knuckles work on my civic and I can get a perfect alignment. someone help please..
https://cimg3.ibsrv.net/gimg/honda-t...c1b3051077.jpg pictures just showing what i started with, nothing to do with my question really |
Re: 97 civic dx brake upgrade
The knuckles swap right out. May be a tad taller, but it’s not a huge deal. Upgrade to a 15/16” or 1” master cylinder might be a good idea, too.
Originally Posted by Freedo_Civegra
(Post 51916191)
You'll probably need a camber kit anyways. See here for details on your options.
https://www.k20a.org/forum/showthread.php?t=29191 |
Originally Posted by tony_2018
(Post 51916303)
Originally Posted by lonely_driver4
(Post 51916262)
if they swap out would an alignment be an issue? I would like a perfect alignment no camber or anything, do you know this from experience? I know they will bolt up I'm concerned about alignment. also can I use the MC off the integra? I have the integra trailing arms for my car also
I used an MC from a 2000 Integra Type-R. Bolts directly to the brake booster, and the lines attach without having to bend them. Integra rear trailing arms are identical (afaik) to the Civic Si.
(Post 51916321)
would a camber kit just consist of adjustable upper ball joints?
EDIT: I’d get Hardrace uppers if I really needed some. Some people hate in Megan stuff, but I didn’t want to spend an arm and leg for something I wasn’t sure was necessary while at the same time wanted something better than eBay quality. |
okay thank you everyone very much, one more question I could return the integra knuckles to the junk yard and swap them out for civic EX knuckles. I've rear the integra calipers can be bolted onto the ex knuckle with zero issue. would this be a better option?
(Post 51916364)
