97 Civic cx A/C problems
#27
Re: 97 Civic cx A/C problems
Okay. Back in cooler New York and re-tested system after full evacuation/refill. Results below. As you can see low side and duct temp values are spot on. High side is too high. Clogged lines or restricted condensor. According to my mechanic, clogged lines are not common. I will start with condensor.
#29
It's not #1, unless air is getting in somehow, don't think that's probable.
The condensor fan runs properly, I just replaced the old cruddy ground on it.
I'm not sure how they make a distinction between restricted lines and a restriction in the condensor; a loss of flow is a loss of flow. Anyway, since it is the only original component left in the system I will replace it and see what happens.
bluestone
04-03-2018 09:42 AM
