97 civic cx - bad misfire and backfiring
i have 1997 honda civic cx and can't figure out the problem.car is hard to start then when it starts idle is fine rev it up and lots of back firing won't rev past 3000 rpms and at 3000 rpms punch it and bogs hard.please need some help.also changed plugs,wires,and fuel filter.
The Grumpiest
Re: bad misfire
Jump the service connector then. If you cannot pull codes we can't really help you much. Especially since getting info out of you is like pulling teeth.
Check your timing.
Check your timing.
Re: 97 civic cx - bad misfire and backfiring
inside the distributor looks fine but from looking on the web saw other cars with same problem being a bad distributor
my brother had a problem like this in his da it was the tps or map he just changed the whole throttle body if it revs up all the way when u dont step on it just rev normal than were in the same boat just mine bogs after 4000 rpm
