96 honda civic lx knocking motor
My sons motor is knocking its a d16y7 he is wanting a d16y8 however im not a honda man so im asking you guys what should he use. he wants the best bang for the bucks and he dosnt have tons to do converting needs to be a bolt in swap or as little changing as possible. Also does anyone here know were i can pick up one reasonable.
Resident Gearhead
Re: 96 honda civic lx knocking motor (butchman)
Swapping to a D16Y8 is not much of a big deal, switch to the D16Y8 ECU (P2P) and run a few wires from the motor to the ECU harness. All the other accessories are compatable; power steering pump, AC compressor, alternator, axles etc.
I drive a D16Y7 every day and I am not a fan. Upgrading to a D16Y8 is not a bad idea.
This would be a good project for him to learn from as well.
Seagull Management
Re: (butchman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by butchman »</TD></TR><TR><TD CLASS="quote">been talking to motor folks trying to get the mnotor and they all say i have to change the computer intake exaust and thewireing harness. is that true</TD></TR></TABLE>
Intake yes, exhaust no, D16Y8 manifold and downpipe is considerably less restrictive though, but requires a new cat and some custom exhaust work. you will need a P2P ecu as mcvtec already stated. You will need to run 2 wires + a ground for vtec. If the car is an automatic and it is to remain that was thats all your wiring, if its a manual you will need to preform what is known as the "IACV fix".
Edit, forgot to mention, make sure you buy a manual engine if the car is a manual, automatic if its an automatic, the intake manifolds are differerent.
Vtec and IACV pinout below.
Modified by 94EG8 at 6:49 PM 10/20/2008
luv2splooge
09-16-2010 10:27 PM
