96 ex with d16y7 swap bad idle too much fuel wen cold
got a 96 coupe with a 97 cx d16y7 motor in the car, everything is stock in the fuel system, fp shows 38psi, stock inj, fpr, pump is still good i, and fuel filter is new, y am i gettin so much fuel into the car , like it wont even stay on unless u keep your foot on the throttle to warm it up, but when its warm,ed up, the car idles alright
Re: 96 ex with d16y7 swap bad idle too much fuel wen cold (Hockey27925)
did you use the ex injectors ? what ecu... the y7's have smaller injectors than the y8's .. 190cc vs 240... if you used the ex injector on a y7 ecu its going to run hella rich
Re: 96 ex with d16y7 swap bad idle too much fuel wen cold (ReDHaTcHyGuy)
o wow really i think im using the injectors from my gsr that i still have, maybe thats y it cant even run right, i thought all honda injectors were 240cc so i figurded id use those instead, do u no which injectors i can use so that i can make them fit my harness that i made for the obd1 injectors cuz i dont want to splice out thee injectors again, but if i have to then i will.
