96 ek b series swap help
96 ek hatch obd2a
96 b18c1
96 gsr tranny
99-00 si engine harness obd2b
99-00 si speed sensor
the speedo isnt working and I cant figure out why.
it doesnt work with the 99-00 si computer or a p28
the tach wasnt working either but I ran a wire from the blue wire on the dizzy to the blue wire on the drivers side shock tower and that works now.
96 b18c1
96 gsr tranny
Re: 96 ek b series swap help
the gsr tranny had a metal vss and 99-00 si harness the plug for the vss wouldnt plug into the gsr vss so i got a plastic vss from a 99-00 si put that in the gsr tranny and the harness plugs into to that vss
so is it working now? i had this problem before. turned out to be a blown altenator fuse located under the steering column. its fuse 15(7.5w).
the engine harness is 99-00 si obd2b
and the ecu is 99-00 si obd2b
the harness that plugs into the engine and ecu had 3 plugs 2 that plug into the ecu and one green plug that plugs into the under dash harness
i got the tach to work but i cant figure out whats going on with the speedo
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/speedo-quit-while-driving-2545274/
Read his post on the 1st page and go to the TSB link.
Seagull Management
Yep, I can pretty much guarantee you thats the problem. I don't know how many times i've seen this question asked. If you plan on running a '99 - '00 Si engine harness in a '96 - '98 Civic you must also use a '99 - '00 dash harness or you wont have a tach.
the car is a 96 obd2a
the 99-00(OBD2b) underdash harness is REQUIRED if you are trying to use a 99-00 engine harness. the green plug which connects to the underdash has the 3rd plug for the ECU on it.
i KNOW, ive done it.
thank you.
alright so in order to get the tach and speedo working properly I have to get a 99-00 si under dash harness?
how hard is this harness to change? do I have to pull the dash out?
is swapping the under dash harness a for sure fix for the tach and the speed? also this under dash harness where does it plug into?
your options are like this:
-buy a 96-98 ex engine harness.. and swap out the 99-00 si one.
OR
-buy a 99-00 si underdash harness.. and swap out the 96-98 one..
I think im going to try to get my stock non vtec engine harness back and put that in and use a obd-2a ecu and run a wire for vtec
