96 del sol si rear wheel play
Old 04-07-2013, 07:00 PM
Lizardslap's Avatar
Icon2 96 del sol si rear wheel play
OK so I have this rattle coming from the rear passenger side of this car as well as the rear passenger tire has play in it.
SO far I have replace that wheel bearing, sway bar end links, trailing arm bushings, rear lower control arms, and rear struts.
the wheel bearing did not come with a new spacer or axle nut so I had to reuse those.
any Ideas on how to fix this wheel bearing play or rattle
I also torqued the wheel bearing to 106ft/lbs
the car is a 1996 del sol si with rear disks
Old 04-07-2013, 07:23 PM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Default Re: 96 del sol si rear wheel play
Punctuation is your friend!!! I gave up trying to make sense of the run on sentences.
Old 04-07-2013, 07:33 PM
Lizardslap's Avatar
there hope that is more clear Idk why I pushed yes when I thought it looked bad to
Old 04-07-2013, 07:44 PM
goldsy's Avatar
I believe the torque spec is 134 ft/lbs. Give that a try and see if it helps.
Old 04-07-2013, 08:03 PM
Man that is much better!!! Did you press the bushing yourself? Is the play in the bearing or possibly coming from one of the bushings?
Old 04-08-2013, 04:38 AM
Lizardslap's Avatar
I did not press the bushing myself I got new lower control arms.
I tore up the threads trying to get the old sway bar end links out out.
I did put the the car on the ground before torquing them in.
The only bushings that are not new on that side of the car are the upper control arms.
The play is definitely the wheel bearing
I replaced the hub with a new one
I will torque to 134ft/lbs after work today
Old 04-08-2013, 01:02 PM
Lizardslap's Avatar
Ok so I replaced the axle nut and torqued it to 140ft/lbs
Also rotated the tires thinking it might be the rim but no
there is still play in the wheel
I was talking to a mechanic and he said that the washer inside is a crush washer and should be replaced
If it is a crush washer where can I find a replacement
dek1mfk
02-07-2007 03:55 PM
Pavix
03-01-2006 11:49 AM
dmg2006
01-02-2006 07:48 PM
crxgator
10-25-2004 04:20 PM
Quick Reply: 96 del sol si rear wheel play
