96 civic sohc 1.6 vtec engine problems
i have a 96 civic , which i recently changed motor and tranny for which i blew the old one . Now has a 1.6 S O H C V Tec . Check engine light was on so i got codes from comp , po113 (intake air temp sensor circuit high voltage ) need to know where this is located on intake which i have another intake that i can swap this sensor with ???Also po141 (secondary 02 sensor ) and po700 (automatic transmision control system )which tranny bangs when going into first and coming out of first gear ??? but is ok when past first gear . Since then incountered new problem while driving car , on parkway doing about 70 engine bogged down ,let off pedal gave it gas ok for a minute bogged down again ??? felt like it was overheating but temp was exactly at half not higher than normal . then engine shut off but started right back up ??? drove two blocks shut off again ??? Does anyone know what this problem might be ??? Know Comp dont always tell u what the problem is , dont want to drop alot of money on parts i dont need .???
having problem with sohc 1.6 vtec , bogging down ?? know there is a bad sensor on intake (IAT) also 02 sensor. any technical help will be appreaciated
