96 Civic-ls/vtec - code 7,8
Back when my car started having problems I changed out the map sensor, plugs, distributor, and the close code came on and I fixed that and now it's throwing a code 7,8 at me now. Tdc and tps. What would cause this? First code 4 and now code 7,8 and since the ckp it's been in limp mode and hasn't been driven.
re: 96 Civic-ls/vtec - code 7,8
I will check it in the morning.
I have a 96 civic. B18 board to b20 2.0 with a type r head. I replaced the dizzy from code 4 and it have me the same code so I check the connections and the code 4 went away. I thought I had it then it through code 7and 8.
Bad mileage
Limp mode
Runs really rich
Idles really rough
Bad mileage
Limp mode
Runs really rich
Idles really rough
Fish Twig
b18 board? what ecu code is on the metal casing?
Did you check to see if your tps is properly adjusted?
Does this car have a hackjob engine harness?
Yes it's a ls/vtech. 2.0l instead of a 1.8.
The ecu is a hondata. P28
The harness is done right. My buddy who was a tech for many years did that.
