96 civic with JDM H22 Type S motor LSD
96 civic with h22a jdm lsd I just swapped the motor and everything works great runs very hard however I need to change my shocks on my car especially the front ones. The topic is because my passenger axle has a very bad shake when I turn but not the driver side. I know that I needed 90-93 integra so thats what I did and put on. I also need an alignment on my car and tires. Do you all think that my shocks, tires, and alignment are what causing the shake on passenger side. Thanks...
are you lowered? if o the axle may be too long if it is binding, or it could jsut be a bad axle.
oh yeah and you dont have a type-s swap unless it has ATTS...most likely its an SiR-S Sped or jsut an lsd h22a.
Re: (angelgsrteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by angelgsrteg »</TD></TR><TR><TD CLASS="quote">too fast for you huh..............</TD></TR></TABLE>
no...wrong section
no...wrong section
Re: (PHOBIA)
if your car is lowered like 2" , go to shucks and buy 88-89 teg axles for whatever side thats binding, actually you should buy them for both sides. i had the same prob in my 97 ek, was using 90-93 vibrated all the time when i turned so i tried the 88-89 and no probs at all.
