96 Civic EX -- Rattling noise with transmission in gear
Old 07-23-2007, 09:25 PM
frostykue's Avatar
Default 96 Civic EX -- Rattling noise with transmission in gear
I just bought a 96 Civic EX and somehow when I'm in 2nd and 3rd gear, something keeps rattling from my engine. It kind of sounds like my clutch is shaking but it stops rattling when I get to 4th and 5th gear! Pleads help! i can't figure out whats wrong with this. It seems as though a lot of Honda cars have this rattling noise when in gear! Thank You!
Old 07-23-2007, 09:43 PM
w0ng_sta's Avatar
Default Re: I Need Help PLEASE! (frostykue)
rattling.. like metal vibration?... does it happen when not under load(neutral) try sitting in neutral and revving slowly throught your rpm band.. do u hear the noise? if so have someone else rev up and try and listen to where its comign from.. might just be a heat shield .. if it is.. try to clamp it down.. get some large tbolt clamps and just tighten the ***** down
Old 07-24-2007, 10:19 AM
frostykue's Avatar
Default Re: I Need Help PLEASE! (w0ng_sta)
Well I don't think its the heat shield cause I've checked that. Its weird, like when I'm in 2nd and 3rd its like the clutch is rattling agianst something. Its like ka ka ka ka ka! My girlfriend used to have a 90 civic and it also did that on 2nd and 3rd gear also, thats why I think it happens in civics alot! Thanks man!
Old 07-24-2007, 11:29 AM
Stouts 'n' Scotch
wiZCo's Avatar
If it's something in the clutch housing, maybe one of the springs broke and is rattling around in there.
Does the clutch pedal or shifter vibrate when you hear the rattling noise? Does the tranny slip or jerk when it's rattling?
Otherwise, did you really check out the heat shields? It sure sounds like a loose heat shield to me, most likely the one for the catalytic converter.
Old 07-24-2007, 11:37 AM
instructor74's Avatar
Default Re: (wiZCo)
the easiest way to stop the heat shield from rattling is just take it off then you will know for sure but that is what it sounds like
Old 07-26-2007, 09:22 AM
frostykue's Avatar
the shifter does rattle but the clutch peddle does not though. but it mostly rattles when its over 70 mph. so i dont know whats wrong. and when the car is on neutral when u rev the engine it does not rattle its quiet like normal it jus on 2nd and 3rd gears. when ur on 2nd if its close to 2500 rpm it starts rattling into 3rd and then 4th is fine.
Old 07-28-2007, 07:25 AM
frostykue's Avatar
**Bumb** up for help plz
Old 10-17-2010, 06:44 PM
frostykue's Avatar
After all these years, I have figured out what was wrong. One of the bearings in the transmission is bad. This is what is causing the grinding noise that is coming from the engine when you are in lower gears.
KillerElfboy
05-14-2007 05:40 PM
acura_guy
01-28-2006 02:09 PM
jbashir
06-25-2004 09:43 PM
eggsworth
03-22-2004 12:51 PM
Quick Reply: 96 Civic EX -- Rattling noise with transmission in gear
