96 Civic EX
96 Civic EX
Good morning I just bought a 96 Honda Civic EX, first time really dealing with Honda's the motor has deff been altered the connector for the fuel injector the connector have been wired on....every since I bought it....it idealing very well BUT as soon as you put into gear it bogg down really bad have replaced distributor cap spark plugs and wires...also have replaced the fuel filter..dosent bogg down half as bad as before the tune up but still has almost no power when trying to accelerate or main Tain a speed any seggsugges very much appreciated
I'm not Rick!
Re: 96 Civic EX
TPS. throttle position sensor. you have map and TPS plugs on wrong?
any engine codes? running correct ECU? old gas? run seafoam.
correct spark plugs?(only use NGK)
timing correct? you can adjust it by twisting distributor.
Re: 96 Civic EX
Scan for and resolve any codes. Don't expect car to run properly with CEL on. Then check the cam timing, and set the spark timing with a timing light. Don't just "twist the distributor" and hope for the best.
Eunos242
11-06-2016 05:29 PM
Ohbebe75
09-16-2009 01:20 PM
jdm_vtec
05-19-2007 06:31 PM
