96 civic dx with bad pcm - Will ITR Ecu run engine for drive home?
I am looking at a 96 civic that has a bad pcm. Will my ITR Ecu run the car to at least get it home in limp mode until I get the correct pcm?
Re: 96 civic dx pcm problem
I don't know the answer to the ITR ECU question. But how do you know the ECU is bad? Have you checked the main relay, hood fuse 44 and dash fuse 13, as well as the ground on the thermostat housing?
The most informative thread title helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
Re: 96 civic dx with bad pcm - Will ITR Ecu run engine for drive home?
the car was checked at the local honda dealership and they diagnosed it as a bad pcm. I have a buddy that works there that gave me the heads up on the car. Just got off the phone with the owner of the car and he wants wayyy too much so disregard the post. $4k for a 96 w 98K and it needs work.
MonkeyPuzzle
10
08-28-2007 03:50 PM
RudeLude95
21
09-22-2005 09:24 PM
