96 civic dx/b16b swap - axle problem
i have a 96 civic dx that had a d16y7 in it. and i got a b16b swap that i have bolted in and plugged in. everything was finnaly coming together until i went to put in the b series axles and they are to big for the hubs that are on the car. what are my options?
Re: someone please help!!!!!!!!
well i just ment they are in good shape. and does the 99-00 si have a half shaft or would i have to ditch that off mine if i went that rout?
You really didn't think out your swap, at all. Yes, the SI has a halfshaft. All B series transmissions have halfshafts. I prefer my swaps to be USDM, so I'm not totally up to speed on the CTR differences, but from what 5 seconds on Google tells me, you'll either need 99-00 SI ABS axles, or 99-00 SI non-ABS axles and halfshaft.
well i have a honda and i drive it. i needed a motor and i wanted a good one. one with a little more pep in her step. the company i bought it from made it sound easier then it was for someone like me. that company is full of ****. so that brings me here asking someone who might know. witch is you. for some help. thanks for your help.
It's just as easy as any B series swap. Don't blame the shop because you dove into a project without knowing what it fully entailed. Everybody makes that mistake at least once in their life. I'm in the middle of one right now - I feel your pain.
From what my (minimal) research tells me, ABS was not an option in the USDM SI. If I were you, I would replace the axles and halfshaft together. When an axle gives out in the future (it will happen eventually), it'll be a lot easier to get a replacement if you already have USDM axles.
not just the chip. but the whole ecu. i have looked it up and have heard good and bad things. just wondering if u might know. but thanks for all your help. hopefully ill be on the road soon.
