'96 Civic CX Subframe replacement
I have a '96 CX hatchback (AT with PS) that has a severely rusted front subframe (thanks, upper midwest winter salt!). I am thinking of tackling a swap of the subframe with a salvaged part. I'm wondering what other bushings I should look at replacing as long as I have everything taken apart on the front end.
I replaced the upper control arms two years ago (worn upper ball joints). I had both front half shafts replaced 25k ago. I installed new rotors, pads and rebuilt calipers about three years ago.
Should I think about the lower ball joint? Other bushings or parts?
Thanks for any suggestions.
Re: '96 Civic CX Subframe replacement
Are the ball joints and bushings showing wear? If so replace them... While you have the subframe/rack out replace the rack bushings.
Personaly, I would replace the bushings/ball joints while I was in there.
SpecialRequest
01-20-2016 02:02 PM
hatchaholic
24
09-13-2014 10:24 AM
hatchaholic
09-03-2014 01:51 PM
