96 Civic 5 speed - not able to put it in gear
I bought a 1996 Honda Civic. After I had it a week the problem of not being able to put it in gear showed up. This is probably a reason it was sold. What is causing this?
Re: 96 5 speed?
be more specific there can be a TON of reasons... is there pressure in the clutch pedal? the week that it was driveable, any symptoms? you need to be less vague to get any help!
Re: 96 5 speed?
Sorry about the detail part. New to this. It is a 5-speed manual transmission. I can still drive the car. It has 127,000 miles on it. The problem started out of the blue. I have read a few comments about a hydraulic clutch. Is this somesthing to pursue?
Re: 96 Civic 5 speed - not able to put it in gear
Please describe simple tech problems in the thread title - edited.
If you want help, answer all questions posted in your thread.
Re: 96 5 speed?
It is a 1996 Honda Civic with a 5 speed manual transmission. It has recently become difficult to put the car in gear. When I start the car and try to go in reverse you can hear the gears grind. The clutch does not have much pressure when you depress the pedal. I blead the slave cylinder on the side of the transmission but not much has changed. I blead the clutch with the car running and not running. I do not have a manual on this car. The gears do not slip that I notice it just seems like it does not allow gear change.
Is there a sign to tell which one or do you replace both at the sme time? What is a good manual to get for this car.
Sure enough it has a leak under the dash coming from under the boot. I does not appear to have been leaking much,but it has at least got a leak. It looks like this has been changed before. The slave does not look like it has been changed.
Re: 96 5 speed?
Seagull Management
Re: 96 5 speed?
You should put it in a forward gear then reverse, doesn't really matter which gear, any forward gear will do, or pause after depressing the clutch before trying to shift into reverse.
Re: 96 5 speed?
Done. Changed the clutch master and slave cylinder. Car shifts great. Getting the cotter pin out of the clutch peddle was probably the hardest part.
grlimeira
12-20-2013 07:53 AM
justindenton
02-19-2010 02:07 PM
