96-98 Headlights Moisture Build Up
I know to solve the long term problem I should re-seal the headlight with silicon in the affected area that is leaking. But in the mean time how can I get the excess moisture\fogging out? I searched and came up with one solution a guy said to stick a blow dryer where the head light goes. Any other suggestions? I'm affraid to turn on my head lights in fear I might burn out that bulb if it has moisture build up on it.
Thanks HT.
Example of what I am talking about.
Thanks HT.
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: 96-98 Headlights Moisture Build Up (SRCivic97)
new OEM headlights?
I have some for you, $50 shipped. No condensation, ever.
Re: 96-98 Headlights Moisture Build Up (boostincoupe)
I've seen headmights with 2" of water sloshing around in them. Just do as you read before...take the lamp out, hairdryer to dry it, reseal it. You'll be fine.
Quote: "new OEM headlights?
I have some for you, $50 shipped. No condensation, ever."
Umm. No dude. They are aftermarket. Thanks for the soliciation though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SRCivic97 »</TD></TR><TR><TD CLASS="quote">Quote: "new OEM headlights?
Umm. No dude. They are aftermarket. Thanks for the soliciation though. </TD></TR></TABLE>
No problem. Gotta hustle ya know.
Buy some CTR replicas from luudog55 here on H-T. $120 shipped!
i had the same problem when i bought a set of corners...it sucks but you live and you learn, everything that you buy that is a headlight, taillight, or corner that isnt oem needs to be sealed with waterproof stuff
i used an air hose to blow them out after i hair dried them, then seal them really good so they dont leak again. took me 3 tries to get it right..
dont use the blow dryer you will end up blowing dust in there and there will be water spots on the inside of your lights, just leave in the sun or whatever and dont wash it then when its dry seal away, just my 2 cents
Re: 96-98 Headlights Moisture Build Up (Master Shake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master Shake »</TD></TR><TR><TD CLASS="quote">Drive around with your highbeams on during the day.</TD></TR></TABLE>
Yeah, see I was thinking about doing that to dry them out, but wont moisture on the bulbs burn them out?
Imperious: Mod of Valor
Re: 96-98 Headlights Moisture Build Up (FlatBrokeHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBrokeHatch »</TD></TR><TR><TD CLASS="quote">I've seen headmights with 2" of water sloshing around in them. Just do as you read before...take the lamp out, hairdryer to dry it, reseal it. You'll be fine. </TD></TR></TABLE>
All you need to do.
All you need to do.
1 Post
seen that in a 94-00 integra when i was following the lady.. it was sloshing around like crazy... half way up the taillights....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SRCivic97 »</TD></TR><TR><TD CLASS="quote">I know to solve the long term problem I should re-seal the headlight with silicon in the affected area that is leaking. </TD></TR></TABLE>
yeah i've seen fish live in altezzzzas "style" tail lights. Pretty nice koi too.
in all seriousness.. If you ever buy aftermarket head or tail lights, do yourself a favor and seal it all around with liquid silicon.
liquid_imagination
Honda Civic (2001 - 2005)
20
10-03-2008 08:14 AM
