96-98 hatch fog light installation? [square]
need a write up i tried searching no luck.. https://honda-tech.com/forums/images...s/emthdown.gif
http://www.passwordjdm.com/pro...D=253 |
Re: 96-98 hatch fog light installation? [square] (pinoyboiwonder)
Same thing as the OEM ones as far as mounting.
http://www.hondaautomotivepart....html Wiring is similar to this... https://honda-tech.com/zerothread?id=1352749 For the fusebox plug... 1. Put in slot 1 if you want the fogs to work anytime. 2. Put in slot 2 if you want the fogs to work with the headlights turned on. |
Re: 96-98 hatch fog light installation? [square] (BlueIntegraBoy)
its pretty basic if you look at it.. i mounted mine without the brackets because they were broken from the accident of the person i bought them from...
but ill look through my helms and see what i can find for u |
thanks.
