96-98 civic auto to manual wiring - reverse lights
Old 09-27-2008, 05:29 PM
confidence's Avatar
Default 96-98 civic auto to manual wiring - reverse lights
this is what you need to do if you are using an auto wiring harness for a manual engine swap.
if you use the auto harness you won't have the reverse lights work since the auto uses the auto control module to switch on the reverse lights.
you need to connect the 2 pin revers light sensor plug to these 2 wires on the Dash harness. as far as i can tell i doesn't matters which wire goes where.
here are the wire you need to connect to
a closer picture of the 2 wires
Sonic198919
09-04-2013 08:53 PM
bonjoey
06-08-2011 04:18 AM
civic_ceze
Honda Civic (2001 - 2005)
11-02-2009 06:55 PM
redline75
10
09-27-2006 10:03 AM
confidence
09-23-2003 09:04 PM
Quick Reply: 96-98 civic auto to manual wiring - reverse lights
