96-98 brake lines more expensive than 99-00 civic?
does anyone know why oem hard brake lines from a 96-98 civic
are cheaper than a 99-00 civic?
(the brake line from prop. valve to rear brakes under the chassis)
96-98 part # 46330-S04-000
99-00 part # 46330-S04-L00
check it out at http://www.hondaautomotiveparts.com
and whats the change in design?
to be honest i can't tell.
Re: 96-98 brake lines more expensive than 99-00 civic? (gangfer)
might wanna read this before you do business with them https://honda-tech.com/zerothread?id=978033
and my guess would be because they can exploit the fact that the 99-00 brake lines are for a NEWER model. but like i said, just a guess
Re: 96-98 brake lines more expensive than 99-00 civic? (DOHC4life)
i dont know the difference betweeen the two but if your doing a 99-00 si brake swap all around like me you can use the 96-98 lines just fine.
DSRxSALSA
04-29-2004 02:19 PM
