96-00 hatchback with Suspension Techniques Sway bars
can you help me out with installation. i cant picture the front sway bar under the car. i cant find the bolts where the bushing are supposed to be bolted on to. Moderators can move this to tech if you want.
Re: 96-00 hatchback with Suspension Techniques Sway bars (GoSpeedRacer)
well..do u have the kit that is made for vehicle with lca's that DONT accept factory sways? ..if so..peep this link..its for an eg but should be similar..
http://tech.hybridgarage.com/tech/swaybars.html
Re: 96-00 hatchback with Suspension Techniques Sway bars (JaeOne3345)
yeah thanks for that but ive already seen that link. im just wondering if any EKs around her got one.
i thought you couldn't mount a front sway bar on a 96-00 ek cause there are no brackets to mount it on, therefore you would have to get the front LCA's from an EX or SI? correct me if i'm wrong.
i just got my beaks kit rear itr sway bar for my hatch. i would like to get the Si front sway bar, but i think i need to swap my front LCA first.
good luck with the ST sway bars
Re: 96-00 hatchback with Suspension Techniques Sway bars (cre18)
that's right...you need the front LCAs from an EX or Si. I have some SI LCAs from my b16a2 swap and I have the ST F/R setup. It will be for sale soon. I'm going to go with a 22mm ITR bar w/ the SRK.
Re: 96-00 hatchback with Suspension Techniques Sway bars (madtownhonda)
just yesterday i was trolling through the overboost how to documents and came across the instructions for the install of the st sway bars on a 2000 dx, which doesn't have control arms equiped with mounts for the sway bar end links. it says the kit includes brackets that bolt up to the lca's to mount the end links to. check it out. i hope it helps and your kit came with said brackets.
http://www.overboost.com/story.asp?id=445
[Modified by isotopesope, 12:04 PM 6/26/2002]
[Modified by isotopesope, 12:29 PM 6/26/2002]
bw54867
11-03-2002 11:39 PM
1993, 9600, blue, civic, front, hatchback, honda, install, installing, springs, supention, suspension, swaybars, techniques
