96-00 civic driver side engine mounts all the same (b16/D16)
do all 96-00 civic use the same driver side engine mount b series or d series? will my stock one bolt onto a LS motor?
Re: 96-00 civic driver side engine mounts all the same (7808)
yes...all the same
Which mount are you talking about?
http://www.hondaautomotivepart...81%29 http://www.hondaautomotivepart...84%29 |
Re: 96-00 civic driver side engine mounts all the same (gabebauman)
" 4 " in those
i want to know if i can bolt it up to a LS |
No, you need the block mount from an em1
http://www.slhondaparts.com/images/PCI/13S020/024/1.jpg Number 8 and corresponding studs 22 (integra studs are thinner) This will fit the "number 4" mount that is on the chassis bracket - 11910-P30-000 stud - 90041-P01-000 |
thanks.
so i already have the b18 in my 96 civic with a egay engine mount, i want to replace it with oem, i have a stock 96 civic mount, cant i just use the mount with the braket already on the ls ? |
no, the alignment of the studs, as well as thickness (as mentioned) is different - it will not fit the ek mount
ok ill take your word on it, cause im out there lookin at both cars and the studs look identical to the eye
(i have a stock 96 civic and a ls swapped 96 civic) |
