95 vx - need help installing manual transmission
Old 04-28-2012, 09:16 PM
EG-SIXV-TEC's Avatar
Post 95 vx - need help installing manual transmission
Im changing my clutch for a 95 vx and i now cant seem to install the transmission on. Ive been trying and trying for hours. And its hella tiring. The other problem is that i cant get it to slide in. I got the fork and bearing on the trans. The clutch alignment tool looks feels aligned to theflywheel bearing, clutch, and cover. Is that the problem? Idk.
Also when installing the trans. On the engine i found out later its hard to install the trans mount thats facing the front pass tire. Also trying to install the trans with themount. What is the prob. I got it almost in the beginning with the both pin looking things linned up half way bit couldnt go in. I got hard time removing it also now installing is hard. Idk whats wrong is it supposed to go in easy idk whats wrong.
Old 04-28-2012, 09:36 PM
Arthas's Avatar
Default Re: help what to do installing transmission
You have to play with it, theres probably something in the way. I know when Im putting a D or B tranny back in, it takes about 45 minutes of putting it in.
thaimonkey
06-28-2005 10:15 AM
-Whitey-
01-09-2003 07:50 PM
bocian
11-06-2002 06:35 AM
S13Koop
09-28-2001 07:58 AM
Mr. Vapor
08-28-2001 11:48 AM
Quick Reply: 95 vx - need help installing manual transmission
