95 lsvtec turbo help!
i have a 95 civic ex with a freshly rebuilt ls vtec! when i say fresh i mean new piston rings rod bearings main bearings and head gasket! i have new oem head gasket arp head studs! the block has wiseco pistons gsr rods and gsr crank with a 2000 gsr head! i went to get it tuned saturday and it wouldnt rev past 3k the check engine light stays on and when i put a paper clip in the green port it still stays on and dosent blink a code i tried 6 ecus new map sensor and tried switching the map and tps senor wires around! idk wat else to try any info on wat is wronge sry so long thanks!
ko2performance
Engine Machining & Assembly
03-15-2016 10:03 AM
ko2performance
03-12-2016 07:11 PM
