95 ignition wires hacked up
So began looking into the '95 ex 5sp civic. It appears something's have been messed with under the steering column. First issue is the 2 blue with white striped wires from the right side of the tumbler. They appear cut and for the life of me i can't find their original home. Then there is the the same looking wires going to the end of the switch, and when pressed it beeps like the key is in. Then there is another switch with the larger white brown wires and a connector. These three are in the second picture. Ill do some more digging but any insight in to how this is supposed to be would be awesome! Also I've been searching for a diagram of these wires but my colors don't match up. Thanks.
And I suck at the pic right now...so well get that later
Re: 95 ignition wires hacked up
Well ill get the photos loaded tonight, I've got a switch with 2 white/brown striped wires. A switch with 2 blue/white striped wires and a plug with a white/blue stripe and black/red stripe. Finally the double blue/white striped wires are cut. Really just a wiring diagram or exploded view of the ignition tumbler under the column would be super helpful. Again, I suck at the photos on my phone and will get them later
Ok, here's the wires/ switches I'm dealing with.
From left to right.
Switch with 2 white wires w/ brown stripe
Switch with 2 blue wires w/ white stripe - this activates the key in buzzer.
Plug with 1 white w/blue stripe and 1 black w/ red stripe
Finally on the left, the 2 blue w/ white striped wires that connect to the far right of the tumbler, right by the key hole, and are cut with no obvious cut wires under the dash.
I have been searching for a diagram picture or anything with a clue to indicate where these go or connect to ect. Again this is a '95 Civic EX with the 5 speed.
From left to right.
edgeprox
05-18-2011 09:42 AM
Einhander276
02-15-2011 06:19 PM
