95 honda civic vtec need help plz
my car died one day come to find out it had no spark so i changed out the ignition coil and the module it has spark now but the firing order is messed up i changed it around to see what would happen it started up but it was sucking a lot of air in i mean alot what would be the cause i used the ignition coil and module out of a 95 honda civic 16 valve would that matter i have a 95 civic d16 1.6 vtec. would it be the timing belt.
Re: 95 honda civic vtec need help plz (dionysus)
i'd love to help... but i have no idea what you said
maybe a period or a comma or something would help
if my assumption is correct you are saying that you are sucking in a lot of air in through the intake? meaning its loud i think is what your saying at idle in my 95 si that has the same motor i can clearly hear the intake sucking air in it is loud and just how they sound if you have an aftermarket intake
ok i had no spark so i used the ignition coil and module out of a 95 civic 16 valve and i have a 95 civic vtec (would that matter).well it worked i have spark but the firing order is messed up its like 1342 or something when i had my car running i had it in a different order but it was sucking a lot of air through the intake if i put my hand right there it would get stuck big time someone said it might of slipped a tooth on the timing belt i dont know
Re: 95 honda civic vtec need help plz (EGhatchguy)
that sucking air issue u have should b regular if u have aftermarket cai and make sure u use the same ignition coil from the vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dionysus »</TD></TR><TR><TD CLASS="quote">ok i had no spark so i used the ignition coil and module out of a 95 civic 16 valve and i have a 95 civic vtec (would that matter).well it worked i have spark but the firing order is messed up its like 1342 or something when i had my car running i had it in a different order but it was sucking a lot of air through the intake if i put my hand right there it would get stuck big time someone said it might of slipped a tooth on the timing belt i dont know</TD></TR></TABLE>
WAAHT??
i think the ignition modules are the same, i know the coils are. you sure you don't have the plug wires in the wrong order?
use some periods next post
WAAHT??
Seagull Management
Yes you can use the coil and igniter out of a D15B7/D15B8, actually you can use every part of that distributor except for the actual outer casing, everything else is interchangeable. Below is the firing order.
Modified by 94EG8 at 9:59 PM 10/31/2008
Fenix
03-11-2004 11:18 AM
