95 hatch a/c / temp gauge woes
So my temp gauge has been stuck on hot, not over heating but pretty high. It turns off with the car bu then goes back up so I thought maybe water pump/thermostat since my a/c was warm too, and I just recharged it recently. Anyway I was having the timing belt done soon, so I had it done w/ the timing belt, but the gauge is still stuck on high. The shop thought it was the temperature sender for the gauge so I looked it up, and I can't find the right sensor, according to the FSM, it a yellow green wire, but none of the three sensors I found have a yellow green, could mine be a diff. color or am I just missing something? Also, as far as the a/c is concerned, it shouldn't blow warm if its just the temp. switch/sender because that just sends the temp. to the gauge right?
Re: 95 hatch a/c / temp gauge woes
Back from the dead, so my gauge is fine, but neither fan turns on, I checked the wiring, and I'm not getting power through the cooling fan wire, but if I give it 12 volts it turns, and I checked continuity. So I was thinking its the cooling fan switch, but where is this?
Thermoswitch was bad, jumped the switch fan kicked on, replaced thermoswitch. Both fans turn on, but car still overheats, and a/c doesn't blow cold.
Not losing any coolant, I had the thermostat and water pump changed 2 weeks ago with the timing belt, but maybe the shop screwed up. I'll check the A/C I recharged it recently, but the engine is still hot.
It's important that you bleed the cooling system. Some trapped air may be blocking proper coolant flow. Do you know how to do this procedure?
It helps to park the car on an inclined driveway with the front higher than the back for this procedure. You could also put the front end on stands. Don't forget to use the bleeder bolt and to turn the heater lever to max heat.
There's no need to drain the coolant. Just do the bleed portion of the procedure:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
That's only the bleed bolt step, right? Now top off with coolant and let the engine idle until the fan comes on twice.
I did initially, but the car is overheating so the fan never turned off, so I just let it run for a while, it didn't run in two distinct stages, so I went back out and tried it again, but now all the sudden the radiator fan won't turn on despite the car overheating, so I'm going back out to check my fuses. You're supposed to still keep the heat on right?
I only jumped it to test the fan switch, once the fan came on I knew the thermoswitch was bad so I changed it, and didn't have to use the jumper, so the fan was coming on on its own til like 10 minutes ago.
Go ahead and jump the connector again to see if the fan will run continuously. If so, I think you have air trapped around the thermostat housing. This may be preventing the switch from getting hot. Continue with the bleed procedure with the connector jumped. You need to try and get all the air out. Do you have the front end raised? Is the heater set to MAX?
Ok, did everything, bled with it jumped got some air out, with front end raised. Car still does not cool. Oddly, A/C fan worked yesterday despite A/C still being warm, but today A/C fan won't spin at all. Radiator fan still wont' spin w/o being jumped, I'm beginning to wonder if the shop gave me a faulty switch?
The A/C Fan relay seems to be bad, as well as the fan switch despite just getting a new one, I may also have a leak in my A/C. Getting a new fan switch and relay monday.
Got a new relay today, thought it was bad because I jumped the a/c fan relay just for a second, and it worked, and I followed the FSM flow chart, and it said the check continuity on the blu/red wire on the 2 pin connector on the condenser fan and there was continuity so it said replace the relay, and as stated above I did, but still nothing.
Nothing new today, but noticed green a/c light doesn't come on, does this mean anything or than a possible broken bulb? all other lights on climate control are fine
