95 EX No Start
95 EX No Start
Working on an EX SOHC Vtec. Turns over fine, has fuel but no spark. Is the distributer power/control through the main relay and could this be the primary cause. If so where is the main relay on the 95 EX 4 door. BTW new coil, cap rotor button, wires and plugs, good comperssion. Any ideas? Does any one have the distributor and main relay schematic?? Sure could use some help!!! It was running fine till the week it quit. I checked the rotor its tight.
Re: 95 EX No Start (tpr)
Try taking the distributor off and rotating in 180 degress. If that doesnt help try and ohm out your coil and see if it is burnt up.
this is in an older hatch or crx right? if so are you using the 95 harness and ecu? if you are then rotate the distributer 180. But if you are using the older si hatch electronics then you have to use the older si distributer.
