95 dx acceleration issue automatic
So i have no cel, i just did a timing belt, waterpump and all accessory belts job. When i gun it it barely moves, maybe 10mph. In reverse its fine, and in neutral and park it revs very well. Any ideas?
Thanks in advance. |
Re: 95 dx acceleration issue automatic
99.99% chance your ignition and/or mechanical timing are off. Check them again.
I'm leaning towards mechanical timing since the timing belt was replaced. Double check to make sure everything lines up, make sure idle is set properly and then check ignition timing.
I did forget to also mention i did the dizzy before i did the timing. Ill check that also.
