95 Del Sol - No Fuel?
#26
Re: 95 Del Sol - No Fuel?
[QUOTE=muellersfan;51962197]My pleasure
Set the meter to the 200 Ohm scale.
Touch the meter probes together. What is the reading?
Then make the readings above again.
The reading was between 1.0 and .9
I am headed out again to test the car
#27
#28
My pleasure
This seems to be a problem. Were the wires at these two pins Yel/Blk?
Now move to the main relay connector, but do not unplug it.
What voltage do you read at main relay connector pin 3 (Yel/Blk wire)?
Tested them all again at 200 Ohms and they were all 1
B1 is blue with silver dots and A25 is brown
#29
they are opposite to where I thought they would be. I will do them all again. I was counting from the holes in the plugs, but looks like I need to think of it like a mirror image of the ecu.
A23
A25
A26 are all 1
B2 starts in the range of 16 and then slowly settles to 6.9. if I hold it there, it continues counting down very slowly, until my hand cramps and I can't hold it anymore.
#30
Is below the summary of your results?
A26 (Blk/Red) = 1 (no continuity to body ground)
B2 (Brn/Blk) = 6.9 - 16 Ohms (continuity to body ground)
A23 (Blk) = 1 (no continuity to body ground)
A24 (Blk) = 1 (no continuity to body ground)
A25 (Yel/Blk) = battery voltage
B1 (Yel/Blk) = battery voltage
Pin 3 main relay (Yel/Blk) = battery voltage
#31
#32
#33
#34
I ran through them all again this morning using your color guidelines. These are my findings:
Continuity at 200 Ohms
A23 (Blk)1.2
A24 (blk) 1.2
A26 (blk/red) 1.2
B2 (brn/blk) 1.2
Battery Voltage = 12.2
Key On Voltage test
B1 (yel/blk) 12.1
A25 (yel/blk) 12.1
Main relay Pin 3 Yel/Blk) 12.1
#35
A23 (Blk)1.2
A24 (blk) 1.2
A26 (blk/red) 1.2
B2 (brn/blk) 1.2
Key On Voltage test
B1 (yel/blk) 12.1
A25 (yel/blk) 12.1
A23 (Blk)1.2
A24 (blk) 1.2
A26 (blk/red) 1.2
B2 (brn/blk) 1.2
Key On Voltage test
B1 (yel/blk) 12.1
A25 (yel/blk) 12.1
A bad capacitor generally causes this problem, so if you can desolder and solder, replacing all of the electrolytic capacitors on the ECU PCB would be an inexpensive fix.
#36
I will talk to my hubby about it. Hopefully that is something that he can figure out how to do. The man can build a watch (with or without someone asking him the time.) Lets see if he can do this.
You have been a great help. Again, thank you so much for hanging in there with us.
#37
Thanks again.
#38
That looks like the one. Verify it’s bad by measuring capacitance after removal.
A new capacitor may cost you 50 cents.
#39
Yes that capacitor has leaked. After removing the bad capacitor, it's important to clean up all the leaked fluid and repair any circuit traces and / or vias that have corroded through.
#40
Thanks for your response. I will make sure to look up the proper way to do that before I get started replacing the capacitor.
#41
Also even without an ECU plugged in (but everything else plugged in), the fuel pump should run when you turn the key to the starting position. Disconnect the starter first so you can hear the pump.
#42
@muellersfan WOOOOOHOOOOOO!!!!!!
I just wanted to let you know that I received my new (to me) ecu from ebay, and guess what? That test light came ON!!!!
So happy with your help and guidance. I danced a jig when that test light came on...and thought of you!! ECU was $160 on ebay. I did try my hand at soldering, but apparently...I don't math or solder.
Can't thank you enough!
#43
#44
@muellersfan We just turned the key and nothing...scratched our heads for about a nano second. No fuel....OH YEAH! It needs gas in it.
He started RIGHT UP! 2 years sitting and he started right up. I can't thank you enough man!
#45
Haha
#46
Hey guys I have a 95 Civic d15 and it’s not getting fuel or fire I’ve relaced main relay and all fuses. The fuel pump cuts on when I jump 5-7 on relay but not 1-7 I’ve replaced distributor checked ground on thermostat housing I just don’t understand what I’m missing
#47
#48
It’s not blown all of the fuses are good I’ve replaced them all. I’ve checked all the grounds the main relay and fuel pump are brand new. Do you think it could be the computer possibly?
#49
Use a multimeter to check whether installed fuse 31 has battery voltage on both top test tabs. If it does, there is a wire open somewhere between fuse 31 and the main relay connector.
#50
Your test results here^ unambiguously show that the problem is due to the main relay connector NOT getting voltage from hood fuse 31.
when I test for voltage it shows up 0.038 is that correct ?
