95 Civic Speedo works part time only
My 95 civic's speedo only works part of the time. For no reason it will work, then next time I look down it won't be working. I don't have to hit a bump or anything, just suddenly it will or won't be working. Also while it isn't working the cruise control still works? With that being said I've pretty much eliminated the speed sensor being bad...and that's where I'm stuck!! Any ideas?? I've pulled out the instrument cluster and checked all the connections best I could but still nothing. Does anyone have a wiring diagram pic or link so I could check the speedo wires themselves with an ohmometer?? Thanks a lot for any help!!
Re: 95 Civic Speedo works part time only (gmay00)
what kinda of motor...dont know about a d series but if its a b series check the speed sensor its located on the top of the tranny if standing in the front of the car its on the left rear side of the tranny on top you cant miss it
Re: 95 Civic Speedo works part time only (clemsonhatch)
"95 Civic Speedo works part time only"
make that bitch get a full time job!! haha
mine doesnt work sometimes when it gets cold... like below 35 degrees.
once my tranny fluid and stuff gets warm it will start to work though.
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec »</TD></TR><TR><TD CLASS="quote">First, I would check the VSS connector for corrosion. I've seen it a few times with cars that are driven in the snow and exposed to road salt.
My 92 CX had this problem and did not set of a CEL.</TD></TR></TABLE>
Resident Gearhead
Re: 95 Civic Speedo works part time only (96lsivtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96lsivtech »</TD></TR><TR><TD CLASS="quote">yup but know that i think about it you would be thrown a cel for a speed sensor i think...</TD></TR></TABLE>
Not always true. Happened to me at least twice...and no CEL.
My 92 CX had this problem and did not set off a CEL.
x4and3r1991
11-14-2011 01:57 PM
rerun07
12-08-2005 08:21 AM
