will this header setup work
Old 04-01-2004, 04:38 PM
acme's Avatar
Default will this header setup work
I have a 97 HX with cold air intake and cat-back exhaust (2.25) w/ Es Oval. Im interested in the DC Sports header. Probably 4-2-1 but havent found one that says, like 96-98 hx they all seem to say just ex. Will this header work fine or whats the deal? Thanks.
Old 04-01-2004, 05:17 PM
In The Garage
Shawn C's Avatar
well, the problem lies with the placement of your stock catalytic converter. your factory header is very short, and the cat is right up front. the header will fit perfectly with an EX cat installed, and you will have to extend the O2 sensor wiring
Old 04-01-2004, 06:43 PM
acme's Avatar
Default Re: (ShadyEH2)
i just went to lou's custom exhaust and asked for a cat-back exhaust i have no clue if i have an EX cat installed.
Old 04-01-2004, 06:46 PM
slammed_93_hatch's Avatar
Default Re: (acme)
read again what he said, the problem lays in the header
Old 04-01-2004, 08:04 PM
SOHC_MShue's Avatar
Default Re: will this header setup work (acme)
it will fit. I would just get the new header and then get 2.25" piping made straight back to your header. Find an ex cat if you care to have a cat though. You will make more power with a straight pipe than with a cat so personally thats what I would do.
ALittleTooHigh
11
10-19-2012 11:35 AM
ozh_hawaiian
09-08-2010 08:01 PM
Knightmare69
03-19-2006 06:17 PM
Nsane1
04-10-2004 08:54 PM
mrsurfermike2001
09-28-2003 07:24 PM
Quick Reply: will this header setup work
