95 civic lx a/c problems, no cold air
ive got a 95 honda civic lx. having problems with my ac blowing cold. compressor kicks on and switches all work (checked connections in and under dash). freon level and pressure are good. the only problem i can see is my ac fan does not work. the ac blows air fine but isnt getting cool/cold. stays outside temp. is my problem just the fan or could it be something else too? i want to find out what all i need to get before i get it. any help would be great. thanks
Re: 95 civic lx a/c problems, no cold air
Fans prob has a bad ground and refridgerant needs a professional charge. the cans at the stores are a top off kit but never will get you the freezer coolness your looking for and have the proper levels inprove gas mileage.
Fix the fan and go from there. Check whether voltage reaches the fan connector and whether the ground terminal has continuity to body ground. If so, the fan is bad.
GearHeadDriver
71
11-03-2016 02:21 AM
Pr0j3cT95dX
18
04-10-2011 02:13 PM
