95 civic idle problem
i have a 95 civic ex just put a newer d16z6 in it. the car will idle really high (2000-2500) when cold and after a couple seconds the idle will start jumping from 1000-2500 untill the car is warmed up. then occasionally the idle will still jump when im at a light idleing or sittin in the parking lot. any one have any suggestions?
Re: 95 civic idle problem
lmao, are you serious????????? are you just guessing?
OP: i have this same problem and from what ive personally read many times is that its 99.9% your IACV, i will post a thread on how to clean it n' stuff
ive clean mine before too and it worked for a little and started doing it again, if you clean yours and it does that bouncin idle again, you may have a defected IACV
Here is a link for bleeding the coolant http://www.hondacivicforum.com/forum...ad.php?t=41650 , but if you haven't messed with anything coolant related that is unlikely you problem. Cleaning your iacv and fitv will never hurt. It sounds like your problem likely is fitv which regulates the cold idle, but it is could also be a combination of both since it is jumping like that. Here are links to clean the two of those https://honda-tech.com/forums/showthread.php?t=1575913 and https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/. The latter is the fitv pay careful attention to the third from last picture and caption. Many people overlook the fact that depending on how far you turn the nylon fitting will adjust your cold idle speed. Additionally you should check for a vacuum leak. The easiest way to do that is take your air filter off, cover the throttle body with your hand and the car should die. If it doesn't die within three seconds then you have a vacuum leak.
2kul
11
07-31-2011 10:36 AM
