95 Civic - fuel, suspension, idle, and gear shifter issues
Hi guys, my current daily drive is a 95 civic coupe. The car is running fine as a fully stock car, but i wanna make it even better. I been notice that my car should has couple of weak points.
1: it runes better with a full tank of fuel than a half tank, when the tank gets below a half, sometimes at lower rpm, the car gets shaky a little-bit, but that won't happen when i have a full tank.
2: when i get over to speed bump or turning, the rear suspension is making some weird noises.
3: the idle gets pretty low sometimes, but without stall, i guess that could be the idle control value's problem?
4: The gear lever whether in a gear or neutral, it has a little bit wobbles, wat i saying is that i can even move left and right a little bit when i in the gear.
Those r the issues im having now, i will appreciate if anyone can advise any solution for me.
Thanks
Thanks
I never narc'd on nobody!
Re: Looking for some solutions from issues
Issue #1 - when was the last time you replaced your fuel filter? Your fuel pump? Your fuel pump sock?
Issue #2 - So get under the car and inspect your bushings.
Issue #3 - Remove, clean, reassemble, and reinstall your IACV and FITV.
Issue #4 - Replace your shifter bushings.
1: yeah, everything is stock, i never replace the fuel filter and pump b4
2: ok, I'll check all the bushes next week
3: wat is IACV and FITV?
4: gotcha
Thanks
