95 Civic EX Motor Swap
Old 12-21-2011, 07:58 AM
  #26
The Grumpiest
grumblemarc's Avatar
Default Re: 95 Civic EX Motor Swap
??? If you're rebuilding the internals then it's doesn't matter. Get a short block as cheap as you can find one
Old 12-21-2011, 08:15 AM
  #27
mieoffex's Avatar
ok thanks
Old 12-22-2011, 07:38 PM
  #28
Steezer's Avatar
Originally Posted by donvito#1
lol hes talking about a 95 CIVIC not a 96-00 civic a gsr motor will drop right into a 92-95 civic the only difference is the rear t bracket , if hes buying the swap the swap will come with all the mounts and will drop right in its basically plug and play
what about axles, shift linkage? would he still use the 99-2000 si or will the stock ones work?
Old 12-22-2011, 09:27 PM
  #29
Marvin1985's Avatar
You could buy a full B18 LS swap for around $1K. Then boost it and run 12 psi all day on stock everything. It's the bottom of the barrel cheapest bang for buck power for an eg.
Old 12-23-2011, 02:35 AM
  #30
The Grumpiest
WTF is 12PSI? That doesn't mean anything.
Old 12-23-2011, 06:26 AM
  #31
Wrona's Avatar
lolol and look at his sig apperently he is getting a K24 swap next year...
i think what these people go to car meets and listen to others oh i run 10 psi on stock internals oh blah blah blah and theyre liek PSI i must be right!!
PSI doesn't mean sh*t it is all up to the turbo
Old 12-23-2011, 06:53 AM
  #32
The Grumpiest
I just don't like it because it's ignorance being passed on to the next unsuspecting person.
Old 12-23-2011, 09:36 AM
  #33
flmzero13's Avatar
dont ever say PSI at grumblemarc lol
Old 12-28-2011, 11:10 AM
  #34
mieoffex's Avatar
OK sry haven't been on in a while but why would you boost a car with stock internals... The compression would be off bad and I dont think it would even work. It also seems pointless running a turbo on stock internals no real power then so you would be robbing yourself.
Old 12-28-2011, 11:13 AM
  #35
The Grumpiest
You obviously know nothing about what you're talking about. Many people are boosting on stock internals, myself included, and making pretty decent power.
Old 12-28-2011, 11:16 AM
  #36
mieoffex's Avatar
How are you getting decent power with stock internals...? And what is decent power to you?
Old 12-28-2011, 11:18 AM
  #37
The Grumpiest
About 200hp. Pretty decent for daily street driving. And if you don't think that is decent for a Civic then you really don't know what you're talking about.
Old 12-28-2011, 11:22 AM
  #38
mieoffex's Avatar
200hp at the crank or to the wheels and its not bad I guess just not to sure about boosting on stock internals. If this is the case why don't I just fix the D16 that I have and run it boosted until it gives out then drop in the B18...
Old 12-28-2011, 11:27 AM
  #39
canadaek's Avatar
Well I want to find one around $1200 and as far as the jukyard goes as long as the head is ok I hope its fine. Like I said I want to rebuild the internals before I even do the swap so I know everything inside will last.
if you can find a b18c swap with a lsd for $1200 i will take 6 please . you really need to do some more research it cost alot of money to go fast
Old 12-28-2011, 11:30 AM
  #40
The Grumpiest
Why are you planning on it failing? That makes no sense to build it up to destroy it later. I'm running stock internals for the better part of 3 years now. No issues past a blown PCV valve.
  #41
Wrona's Avatar
this guy has no clue what he is doing
Old 12-28-2011, 11:45 AM
  #42
mieoffex's Avatar
No not a clue and just building to destroy...
I don't want anything to fail on my car it's my only way around until I fix my motorcycle.
HondaSPEC99
Appearance Build Threads
08-09-2010 07:56 AM
Exploziveaf1
11
05-28-2007 10:19 AM
Turbotype
11-15-2004 08:43 AM
1990civichatch
06-17-2004 04:21 PM
oldirt3277
09-22-2001 07:12 AM
Quick Reply: 95 Civic EX Motor Swap
