95 civic eg questions
95 civix vx... Sometimes (ften) when i turn on the car i hear a noise coming from my clutch. When I lightly press the clutch pedal it stops and when i release it it comes back up. Also when i press the clutch pedal it squeeks (kinda anoying). I also have a very small throttle body and would like to know what diameter would be better. The diameter i have at the moment sucks, the short ram intake that i have can't even fit because of the diameter and i tightened it with the bracket that was provided but it didn't help because it was too small. My intake manifold is also very small. Here is a pic of how it looks.
http://img221.imageshack.us/im...c.jpg
Re: 95 civic eg questions (scorpnaz_)
probably the clutch throwout bearing that is making that sound
and if u were locak i would sell you the manifold your talking bout but to be honest i dont know the exact name. im sure someone will chime in
Re: 95 civic eg questions (H22JDMEG)
my tranny is good, it is just that ever since my clutch was replaced, it started making a whistleling sound and the squeeky sound when i press the clutch down.
Re: 95 civic eg questions (scorpnaz7)
basicly take your tranny apart from your motor. its fairly common i think for that sound i would personally jus get use to it lol
No its not throwout, its your mainshaft bearing, cheap and easy to install. THere is a good thread on here for that.... noise with clutch in--- thowout bearing, noise with clutch out--- imput shaft bearing.
Common probelms is higher milage/rodded hondas
Steve
Steve
as long as you grabbing gears, dont even bother with the clutch, its just a waste of money. that intake you got is some generic **** which is why it dont fit, bigger dont always mean better on your single cam motor, which I might had is not even worth puttin an intake on.
