95 Civic d16z6 Rebuild
I am going to rebuild my motor because it has 150000 on it, I want to build it for turbo. can someone give me a list of parts I will need to rebuild it. I am new to this so I need some help I Have The d16z6 SOHC vtec motor. Also how much do u think it will cost to rebuild.
Thanks,
George
Thanks,
George
Re: (1992Si)
if you just want a little boost, oem internals will be fine with a good tune. if you want a lot of boost then go forged rods & pistons. Your block will need to be notched to clear the pistons. Either route you go, use ARP head studs. The most important thing to keep it from blowing up is a good tune, stay away from VAFC ans FMU's... get a P28 chipped w/ CROME
Re: (teal_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx »</TD></TR><TR><TD CLASS="quote">if you just want a little boost, oem internals will be fine with a good tune. if you want a lot of boost then go forged rods & pistons. Your block will need to be notched to clear the pistons. Either route you go, use ARP head studs. The most important thing to keep it from blowing up is a good tune, stay away from VAFC ans FMU's... get a P28 chipped w/ CROME </TD></TR></TABLE>The block will need to be notched to clear any aftermarket rods, not pistons
Re: (AbitAvenger)
my recommendation,
CP or weisco pistons, a little lower compression. Stock is 9.4 or something. drop down to 9.0
Eagle rods (notch the block)
ACL or OEM bearings
a block guard or sleaves isnt needed unless you are pushing high psi and shooting for 400+
and with head work, a pnp job isnt really needed unless your tryin for 400whp. If you dont rev past 7200 then the oem head is fine.
the Zex cam seams to be a favorite in the d-series.
I'm goin to run ferrea valves, springs and retainers.
and remember, tuning is key to a properly runnin motor.
my .02
ACL or OEM bearings
my .02
Re: (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx »</TD></TR><TR><TD CLASS="quote">if you just want a little boost, oem internals will be fine with a good tune. if you want a lot of boost then go forged rods & pistons. Your block will need to be notched to clear the pistons. Either route you go, use ARP head studs. The most important thing to keep it from blowing up is a good tune, stay away from VAFC ans FMU's... get a P28 chipped w/ CROME </TD></TR></TABLE> why stay away from a vafc? i have a d16z6 wit some boltons ina ef hatch and im using a vafc one? i jus was curuios why u said stay from them?? and if i get my hand on a p28 what would i need to do to make it work in my car
Re: (Efkrew91hatch)
I have VFAC2 in my car with an auto p28 ECU and it works good, I will be doing a trans swap. the VFCA2 did not come with a diagram for my ECU but it works u just got to wing it, keep Vtec at 4800 to 5200 any lower and u will dog the motor. This is one odf the first mods I did to my car and the first thing I did to the motor.
Re: 95 Civic d16z6 Rebuild (95 vtec)
i have a set of ross pistons for D16z6 single cam. 9:1 compression, good for turbo. you can call ross pistons tech line for confirmation. I was planning on putting them on ebay. any questions let me know.
Elitesky
12
08-05-2010 10:48 AM
Black95CivicEx
12-30-2008 02:11 PM
