95 civic/d16y8 & non v-tec head in limp mode - wiring harness?
hey guys, ive been looking for some information on this and couldn't really find my answer..
the wiring harness that i currently have in my car is pretty much kacked into and worn out..
the question i have,
my car is a 95 civic d16y8 with a non v-tech head...
i have found a wiring harness close to me jus cant decide if it will work for my car.
the wiring harness is out of a 1995 civic d15 motor.. will this work??
please help my wiring harness is throwing me into limp mode right now im hoping this will fix my problem.. please give me your thoughts...
Re: wiring harness??
the codes that im throwing are 4- ckp (in the distributer) and 7- tps..
i have replaced both and im still in limp mode?
its gotta be something in my wiring im assuming its pretty worn out.
thats the only thing i can come up with as of right now... thoes are the only codes im getting.. and i have checked the voltage to and from the sensors distributer and the ecu. everything checks out on the tps and the distributor..
can you think of anything else i could check?
the ckp sensor is iside of the distributor, ive replaced that with a new one.
replaced tps along with o2 sensor, coolant temp, ecu, map,
and im still throwing the codes. car starts fine, just stuck in limp mode.
3 month old motor and trans. both rebilt.
The Grumpiest
Are you just replacing the TPS or are you calibrating it? In any case you're just guessing about the harness. You will probably buy one and that not fix your issue either. I'll let some confirm that the harness you're asking about will work or not.
i have replaced it and calibrated it... its right where it should be.. wide open, and closed.. im not too sure what else it could be.
this car is my baby and i really dont want to give up.
