95 Civic Coupe engine blown... Help :[
So an oil leak caused my 95 DX to blow up over the weekend :[
The engine was a modified stock motor that comes in those model Civics...
(d15b7 I think, correct me if I'm wrong about that)...
But the motor is blown, and my Dad is an engine mechanic and will replace the motor only if I can find a stock replacement (d15b7, again correct me if I'm wrong)
I've done a bit of research, and I just can't seem to find another one :[
Can someone PLEASE help me locate another engine... I'm desperate :[
Thank you so much in advance :D
~Tyler~
~Tyler~
Re: 95 Civic Coupe engine blown... Help :[ (SleeeeepyDX)
one place you can find a sohc non-vtec is http://www.asapmotors.com and the engine code is correct it should be a d15b7 if it was still the stock motor.
Put a Z6 in there man, ****, they're a dime a dozen. Your dad won't even know the diff aside from swapping the ECU . Then you can wire up VTEC on ur own, it's two wires. .
Re: (SleeeeepyDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeeeepyDX »</TD></TR><TR><TD CLASS="quote">Any websites or anywhere I can find one?</TD></TR></TABLE>
you're looking at it
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Put a Z6 in there man, ****, they're a dime a dozen. Your dad won't even know the diff aside from swapping the ECU . Then you can wire up VTEC on ur own, it's two wires. .</TD></TR></TABLE> Seriously, go buy a p28 or chip your ecu without your dad knowing, and find you a D16Z6, or a JDM D15B, both are some bad *** SOHC's, and run the VTEC wires. Just my .02
vicpacdo
04-08-2012 09:45 AM
civiclov5u
16
02-23-2011 08:10 PM
playdude
13
06-24-2009 06:20 AM
alterego666ny
05-28-2003 12:49 PM
