95 Civic with codes 1 and 43
Old 04-08-2013, 03:23 PM
Jpeel1290's Avatar
Icon2 95 Civic with codes 1 and 43
Alright so I've been having a problem for a few months now and I've asked around and been looking through the forums but can't really find anything that pertains to my situation.
I've got a 95 dx with a d16, and my problem started when my CEL came on. It would come on and turn off. I jumped it to pull the codes and got code 1 and 43. So I replaced my oxygen sensor and now this is where it gets weird.
When first started my car idles high, normal from what I've heard, once the computer adjusts and the idle drops the CEL turns on. The car runs fine but the light is on. But when the computer adjusts and the CEL doesn't turn on it "sputters/hesitates" in the 2500-3500 rpm range. It does it through every gear around the same range.
I don't even know where to start
Old 04-08-2013, 03:26 PM
EJ8_Man's Avatar
Default Re: HELP!
How's your fuel pressure? What O2 sensor did you use?
Old 04-08-2013, 03:28 PM
Jpeel1290's Avatar
Default Re: HELP!
Sorry kind of a newbie. I'll have to look to see how to check fuel pressure and get back to you on that. Just a Bosch from autozone
Old 04-08-2013, 03:36 PM
jbpnoman's Avatar
Default Re: HELP!
Start by pulling the code.
Old 04-08-2013, 03:37 PM
Jpeel1290's Avatar
Default Re: HELP!
1 and 43 still
Old 04-08-2013, 03:55 PM
Declectic's Avatar
Default Re: HELP!
well 43 refers to your fuel system… checked into that? checked your spark plugs yet?
Old 04-08-2013, 04:44 PM
EJ8_Man's Avatar
Default Re: HELP!
You can check your fuel pressure the ghetto dangerous way. Unscrew the top bolt on the fuel filter. With the ignition in the first ON position the fuel pump should prime, and you should see a fire hydrant like stream of gasoline come out of fuel filter. Please do not catch yourself or your car on fire. A smart ghetto man would put a hose into the fuel filter and route the gasoline into a container. If it's just a dribble your fuel filter is clogged and needs to be replaced. It's a common thing on older Hondas
Old 04-08-2013, 05:02 PM
Former User's Avatar
Default Re: 95 Civic with codes 1 and 43
Please create informative thread titles - edited.
EJ1Shifty
10
11-20-2018 08:59 AM
choppyEG
10-13-2013 12:37 PM
bealj
26
12-18-2011 06:08 AM
tjdmcoupe
10
03-12-2011 02:15 PM
RS'R'
01-13-2007 05:48 PM
Quick Reply: 95 Civic with codes 1 and 43
