95' civic AC problem..
my ac in my car seems to "turn on and off" continuiously.. why i say that is the compressor will work, then seem like its turned off, then work and so fourth.. i can feel the power surges when it does that also... what could be the problem??
Re: 95' civic AC problem.. (Mr.EM1_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1_EK »</TD></TR><TR><TD CLASS="quote">maybe a short or bad ac clutch</TD></TR></TABLE>
i have to agree with the bad clutch on the compressor.
Re: 95' civic AC problem.. (B18bEG6ick)
any other thoughts? i was hoping it was something small.. actually the compressor is something small, i just dont feel like replacin it had to do my wifes last summer..
btw thanks for the input so far.. give me some other possibilities before i start searching!
could using one of those do it yourself freon cause something to go wrong? ive only had the car for 2 months, filled freon a week after i had it..
OK, so you already filled it once?? It wasn't doing this b4 was it??
When an a/c setup gets too low on freon, or the low pressure switch goes bad, the a/c compressor will engage and disengage the way you have described.
Start with those, as they are the most likely, and cheapest repair.
Re: (rick9293sl2)
well thats the thing.. i turned the ac on for a good 5 mins.. no probs.. its after it warms up and you actually drive for about 5 mins it starts doing it.. where the heck is the low pressure switch at?
and yes i have filled it once..
btw, this is my first car with ac all my other ones, my turbo did not allow it
Re: 95' civic AC problem.. (g23_ej1)
Maybe I'm misunderstanding but what I read seemed to be describing how the compressor is supposed to run. Any car I've had...specifically in a 4 cylinder where you can feel the power changes....the A/C kicks on to cool some air then will kick off...the A/C continues to blow...then depending on how hot it is it may kick back on in a minute or two or a few minutes like 5. Still have ice cold A/C on my civic and it runs like that.
Probably a leak somewhere. Same thing happen to my wife 95 civic lx. Turn out there was a leak on the ac evaporator. Replace it and problem was solve. Ice cold AC for the summer.
Re: (turb20_vtec)
well i'll go and get some of that green freon and fill it up to check to see if its leaking anywhere.. thanks for the input guys..
PL_RACER
Honda Civic (2006 - 2015)
07-24-2012 07:20 PM
JesseCRX
23
08-11-2008 04:40 PM
imjustagirl
08-19-2007 08:54 PM
adan CRX
11-26-2003 08:41 AM
