95 civic 4door bseries swap troubleshooting :(
95 Civic 4door
B18B1 w/ hydraulic mt
Ok where i am at now. A few days ago i had a few codes come up and managed to find a miss in the number four cynlinder. Miss was due to a faulty injector so i swapped all four out for a diff set. Ecu was reset and I am left with code 9, 16, 43 ???? Car will turnover and idle then after a few minutes begin to bog down at idle and then return to normal??
Any ideas whats going on....?
Also the sensor located ontop of the intake manifold..not the tb but the actually manifold i noticed i could unplug and no change in motor sound or rpm.
Re: 95 civic 4door bseries swap troubleshooting :(
code 9 - CYP (Cylinder)
code 16 - Fuel Injector System
code 43 - Fuel Supply System
Check all those and everything. also are you talking about the Idle Air Control Valve?
if you are unplugging the idle air control valve and it not making a difference then is it idling high? also did the codes just come up out of no where?
nope idle is right at eight and the codes are after fixing the miss.... its a fresh swap and i am a novice if that explains anything...
well i'm pretty sure you need to change out your cylinder postition sensor but the fuel codes i'm still not getting the reason they are throwing if it is spraying gas, unless... the car may be flooded.. you might need to take your spark plugs out and try to turn it over and see if you can blow the gas out of the cylinders.
Oh i'm sorry, I was confused on your first post, I thought you were saying the car only turns over... sorry.. hmm let me see what I can find for what's going on.
