94' Si coupe (EX): how do you take of door sill without breaking the clips?
I am trying to take off the door sill to the car, and the helms manual referes to push nuts needing to be replaced once removed. However, I don't know where they fall off. I have already pulled two of the four pins in the sill, and now that section is rather loose, and I want to make certain that once I fully remove it, I can put it back, and gain access to the fallen push nuts to get the sill tight again.
Any info?
Any info?
Re: 94' Si coupe (EX): how do you take of door sill without breaking the clips? (Deam)
on my 97 the door sills just pops out and pops back in, no clips break or anything. it should be the same on a 94. just don't make it into a big deal, it's a little plastic piece that'll cost you $2 at a junkyard even if you did screw up somehow (which would be pretty hard to do).
You dont need those. My stupid clips break all the time, whenever I try and fix that darned window problem. It still fis snug and doesnt rattle or come loose at all and I only have 2 of the clips left.
Re: 94' Si coupe (Neptune)
Well, I found that "how to remove the carpet" thread for the EG, and it answer my question.
The sills on the EG are a bit different, as they have this push-nut thingy that the carpet attaches to.
It's all good, honda-tech came through!
mikie44
11-16-2005 08:14 PM
816d16
Audio / Security / Video
03-15-2004 10:03 AM
