94 Honda Del sol
94 Honda Del sol
Several years ago I had a problem with cranking the car. This happened 2 times and I have not had problems until a few weeks ago. I had been on vacation and upon returning it did not want to start. I finally got it to start and had no problems for about 3 weeks and then it happened again. My first thoughts was that it was the fuel filter. I would appreciate any thoughts on this problem
Thanks
Thanks
Re: 94 Honda Del sol (critchi)
Sounds like you may need a distributor Part, the part will go bad, and work when it wants to, that is why it will start most of the time. Try to replace the coil in the disrtibutor and it may fix it, and do a tune up!
Re: 94 Honda Del sol (Hex420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hex420 »</TD></TR><TR><TD CLASS="quote">Sounds like you may need a distributor Part, the part will go bad, and work when it wants to, that is why it will start most of the time. Try to replace the coil in the disrtibutor and it may fix it, and do a tune up!</TD></TR></TABLE>
crispyflame
28
07-18-2013 08:39 AM
SisterFister
04-04-2010 10:28 AM
