94 honda civic sedan engine problems
I bought a 94 civic sedan it came with a D15 motor i swapped it with a ZC vtec engine. but the engine had no distributor and i have no info on this engine. the ZC vtec is d series. i tried looking for the vin number but cant seem to find it. does anyone know any info on this engine or am i pretty much screwed.
Re: 94 honda civic sedan engine problems
ya its because i went out of state so my dad had said he would buy an engine and put it and well he did but he didnt ask for info
if anyone knows how i can find out what year the engine might have came off because it needs a new distributor but i dont know the year of the engine
The Grumpiest
There are stamps on the head. Get them and come back and post them.
Better yet.
SOHC ZC VTEC
VTEC
Found in
1991–1993 Honda Civic Ferio EJ3 (JDM)
1992–1995 Honda Civic EJ1 (JDM)
1992–1995 Honda Domani MA4 (JDM)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Rod Length : 137MM
Rod/Stroke : 1.52
Compression : 9.2:1
Power : 128 hp (95.6 kW, 130 ps) at 6,600 rpm
Torque : 107 lb·ft (14.8 kg/m, 145 Nm) at 5,200 rpm
Redline : 7,200 rpm
Fuel Cut : 7,300 rpm
VTEC Switchover : 5,500 rpm
Fuel Control : OBD-1 MPFI
ECU Code : P70 (Domani), P91 (Civic Coupé), P29
Better yet.
SOHC ZC VTEC
VTEC
Found in
Rod Length : 137MM
Rod/Stroke : 1.52
Compression : 9.2:1
Redline : 7,200 rpm
And you can't just go to the dealer and pick up a new dizzy ?. Or go to a pick n pull if it fits it fits, I don't know how integrchangeable the d series distrubuters are but http://www.d-series.org/forums/engin...stributor.html
I like the tuna here
oh damn now i need to check that too thanks man good looking out cause im trying to fix it up good but its these types of things that stop me
@ryd i was suggesting that mabye a y8 dizzy or something sold over here was compatable(you didn't read the rest of my post)or ebay it's not hard to find one is what im saying
as grumblemarc posted he needs a p70 ecu not a PM6 that is an obd-0 mpfi ecu not obd1... Im pretty sure if he ran a z6 dizzy and a z6 p28 ecu it would work fine. the ZC was almost identical to the z6 here in the states. i see the p70 is not a cheap ecu on ebay. a p28 would be cheaper and work fine. you could also always get a chipped ecu as well. i dont know if u plan to boost later which u would need a chipped ecu anyway.
JDuval
16
10-23-2012 09:55 AM
Rywire
14
08-27-2005 07:57 AM
