94 honda civic 4 door questions? please come on in
ok. heres the deal.. i just bought a 4 door LX..has a d15b vtec..vtec not wired yet but soon ill get to it..running a stock P06.. i have a p28 will be put in when i wired the vtec.. now questions.. i have abs.. would the abs work if i run the p28 ecu.. cause right now my abs light is ON just running the reg p06. and i cnt get it to turn off.. and can i just take out the abs? can someone show me any body taking out the abs on a 4 door civic.
Seagull Management
Re: 94 honda civic 4 door questions? please come on in (efnoobie)
P28 will work fine running ABS. If the ABS light is on my guess would be a rock flew up and broke one the abs sensors, or someone replaced an axle with a non abs version. That said it could be several other things. Removing ABS is really not recommended simply for the amount of work it entails. To do it right you need to replaced the Master cylinder, brake booster and proportioning valve from a non abs integra (RS i believe) and replace the brake lines with ones for a '92 - '95 civic DX or LX without abs sedan.
yea i thought so.. maybe they put in a diff axel..i havent check the ecu... cuz cel is on too.. so i have to figure the codes....you can reset the abs right?
You should be able to reset any code, but it will come back on.
I'm betting on a non/ABS axle being installed.
ABS is nice dude, keep it. Adds value too.
Stopping with my ABS civic versus my non-ABS 4 door is like night and day.
**** works good in these light cars!!
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efnoobie »</TD></TR><TR><TD CLASS="quote">yea i thought so.. maybe they put in a diff axel..i havent check the ecu... cuz cel is on too.. so i have to figure the codes....you can reset the abs right?</TD></TR></TABLE>
turn ignition off, jump 2 pin connector under dash, turn key to on (II). watch the codes flash. The same connector does both ABS and the regular check engine light. To reset ABS codes. turn ignition off. pull ABS fuse B2 for at least 3 seconds, reinsert fuse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95streetciv »</TD></TR><TR><TD CLASS="quote">Stopping with my ABS civic versus my non-ABS 4 door is like night and day.</TD></TR></TABLE>
Yeah, but most of it isn't due to the ABS. It has a lot more to do with the fact that ABS civics got the same front brakes as integras, as well as rear discs, which again are the same as the integras.
Re: 94 honda civic 4 door questions? please come on in (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">
Yeah, but most of it isn't due to the ABS. It has a lot more to do with the fact that ABS civics got the same front brakes as integras, as well as rear discs, which again are the same as the integras.</TD></TR></TABLE>
True that... I do have rear disc on the ABS civic.
One bonus though is that when I SLAM the brakes, instead of SCCCREEEECHHH and leaving rubber with the regular civic, i just hear this little chirp chirp chirp from the tires, as I lose/gain traction with my stop. And also stop in a lot shorter distance of course.
And all i have to do is SLAM the brakes, no feathering needed.
I feel as though I could "out-stop" about anything in this light car. Did A few test runs on an open road.
Of course my seatbelt shoulder hates me afterward.
ABS in these cars sucks, if it goes bad it is usually expensive to repair (with parts that is)
my ABS pump makes alll hell at startup, but then stops and ABS light comes on. if that dont happen, as soon as i am over 25mph the rear sensor(which is bad) makes the light come on.
and compared to a non-abs car my pedal travel is more and softer.
Re: (NastyHabitzCRX)
thanks.. for giving me feedbacks about abs..as soon as i can check my cel..and reset the abs..i could probably find my problem but i havent done that today, busy at work.. OH yea my abs light stays on all the time doesnt turn off. well of course it turns off when the key is on off..i havent check any of the sensor but imma reset the abs 1st... thanks guys.. ill get back at you.
Re: (efnoobie)
found the codes... 7 so imma have to reset every thing thats needs to reset
Modified by efnoobie at 1:05 PM 10/15/2008
Modified by efnoobie at 1:48 PM 10/15/2008
Seagull Management
Re: (efnoobie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efnoobie »</TD></TR><TR><TD CLASS="quote">found the codes... 7 so imma have to reset every thing thats needs to reset</TD></TR></TABLE>
There are 7 codes? or its showing code 7? and which light is blinking codes? CEL or ABS?
Re: (94EG8)
codes 7... its the tps sensor.. i cleaned the sensor and it went away....abs light just stays on....i reset it already still has lights
Seagull Management
Re: (efnoobie)
Have you taken a look under the car at least to see if it has ABS Axles (they have toothed ABS exciter ring on the outer joint, right where it meets up with the front knuckle.
Re: (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">Have you taken a look under the car at least to see if it has ABS Axles (they have toothed ABS exciter ring on the outer joint, right where it meets up with the front knuckle.</TD></TR></TABLE>
no havent got a chance to jack it up and look around.. maybe today..might be axel
