94 ex coupe Mystery small 2pin connector by interior fuse box.. (photo)
I was removing this crazy alarm in the car. It's an aftermarket which had trunk pop, windows up/down. sunroof open/close etc.
There was a lot of relays, modules and wires. Now I found this connector dangling. I've never seen it in action. Does ANYONE know
where does this connect go to?
Please advise, this is near the interior fuse panel section. Thank you! I'm sure theres some crazy experts on here..
O.G. triple O.G.
Re: 94 ex coupe Mystery small 2pin connector by interior fuse box.. (photo)
Keyless entry. That's where you connect your power door look wires to.
Door Lock ~ Green/White (-)
Door Unlock ~ Green/Red (-)
Oh ok! But should that connector be "dangling"? I can't find where it would plug to? Is it supposed to connect to the factory alarm if there was one once? Or... The door locks still work via the button on the doorpanel(driver side).
Thank you so much for the info already.. I was scared i messed something BIG up
O.G. triple O.G.
The plug connector plugs into a factory keyless module, normally located behind the under dash fuse box. The keyless door feature was an option. I've only seen two on the cars I have worked on.
JaySauce
Audio / Security / Video
04-18-2009 05:11 PM
