94' ex auto-starting issues
Just got 94' civic auto. The cars been sitting for a couple months. Owner tells me that a mechanic tells her it's the starter. So we jump the car and tap the starter and starts like a champ. Shut off and starts again. So decide to buy a new starter. Change it out and the car still won't. So decide just grab a new battery since the car was sitting for awhile. So brand new battery and starter and all I get is a click. Any idea or help I need to get the car out of the place it's at ASAP. Thanks
Re: 94' ex auto-starting issues
Is the battery being drained? Is the fuel pump priming? Does the main relay click and the CEL goes off? How are the spark plug wires/spark plugs/distributor? If you plan on using the car, just change the spark plugs, wires and dizzy cap to eliminate it being a no-spark problem. Once that's out of the way, it'd have to be a parasitic drain from the battery, a poor ground (clean the grounds with a wire brush), other wiring, fuses/relay and/or ECU problem.
1baddcivicsi
26
10-13-2006 04:17 PM
