94 Del Sol suspension same as 92 EG hatch?
Re: 94 Del Sol suspension same as 92 EG hatch? (RTW DC2)
Should be. The LCAs maybe a little different because of the sway bars. Someone else may chime in with a definite answer.
what about the dx hatchback model? will the sway bar for the dohc delsol fit in a dx model hatch or will i need the lca also?
Re: 94 Del Sol suspension same as 92 EG hatch? (Dohc93hatch)
del sols have a heavier subframe. i think its the same as the integra. mine is a bitch to drill through for my suspension tech sway bar while my friends civics were easy as hell
Re: 94 Del Sol suspension same as 92 EG hatch? (delslow94)
All Del Sol VTEC suspension parts will swap onto a 92 hatch and generally be better. The front and rear LCA's have spots for swaybars, you get sway bars, rear disks and larger ones for the front. All you will need to fit the rear brakes would be e-brake cables from an Si hatch or EX coupe. I bought a totalled DelSol VTEC and swapped all the suspension parts over and am thoroughly happy.
B88
23
08-20-2016 12:31 PM
IdotheSHOCKER
01-10-2003 08:05 PM
